Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Running dangerously Lean on 1992 FXDC?
Old 12-06-2016, 12:45 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Great to hear that you seem to be on the mend with your bike. Having owned Harleys since the '70s a common sight (and sound!) is a near stock bike with a badly set up S&S carb. Despite that I like them so much I bought mine with a 107" attached! My bike has a G, but the later S&S 111" has an E, which indicates the power range your carb is suitable for. I suspect it can be correctly set up to run right, which the info on the S&S site should help you with.
If your filter cover has any holes drilled into the interior of the air filter, in other words admitting air direct into the carb, chuck it and get a fresh cover.
Old 12-07-2016, 02:54 AM
monchidog's Avatar
monchidog
monchidog is offline
Post
Thanks grbrown, yes I bought a new tear drop air filter cover (man they're expensive!). I did review the S&S website and did a basic set up with their video which was great but i'm hoping the mechanic can set it up a little more precisely! The PO had obviously set it up wth bells and whistles, S&S carb, S&S air filter, Iridium Spark plugs, Straight through drag pipes but it didnt seem to be synchronised at all so hopefully when she's all back together I will notice a difference.
Just got a bit upset at being told she was too old to handle the power!
Old 12-07-2016, 07:34 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,259 Likes on 3,629 Posts
Based on those plugs it looks like the motor is running too rich with possibly too much timing..
Add: Plugs may be too hot also..
Old 12-07-2016, 08:04 PM
Max Headflow
Originally Posted by Hillsidecycle.com
If it was not popping or sneezing thru the carb from the suspected lean condition, I believe that the timing would be the issue creating spark plug concerns.
The 2 are confused by many.
Scott
Old 12-12-2016, 04:20 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,818 Likes on 3,320 Posts
An S&S E is not too big for an 80"er. It all depends on what heads, cam and exhaust your running and the the proper jetting.... Do you know what you have in the motor? I know you said the rings are shot but I'm curious as to what your compression was? Before condemning the carb you need to know what all is in the motor... Any History?
I do not see anything wrong in any of the pic's you initially posted... It all looked normal. Also you don't need the iridium plugs. Standard BPR5es will do great at .038" gap....
2006ultra
EVO
06-13-2014 04:03 PM
rpr921
EVO
11
08-27-2012 10:53 PM
maryland blackout
09-14-2011 03:22 PM
freewill
08-13-2011 02:16 AM
Beefcake
Exhaust System Topics
11
06-02-2005 09:42 PM
Quick Reply: Running dangerously Lean on 1992 FXDC?
