Hesitation on my 03 heritage
Ok guys I'm new to the forum and just bought my firest harley and not sure where to start....I have an 03 heritage I bought about 4 months ago the bike runs great but on take off more in 2nd and third gear if I roll the throttle to quick it's like the power curve hits a wall almost like it's hitting Rev limit but it's only half throttle if I let out and roll again it picks up not sure if it's a jetting issue or what just to give an idea it's running harley high flow air filter and vance and hines longshot no baffels and the guy I bought the bike from says carbs have never been jetted so my best guess is it still running factory jets harley says put baffels back in I tried that it didn't really change any and I lost all my sound just wondering if anyone on here might give me an I deal to start with also harley said try AR torque cones just wonder has anyone had any experience with those any input will be greatly appreciated thanks
Hi from the UK and welcome to HDF.
You have two basic options I suggest. You can either try to learn how to tune your carb yourself, or find a local indy who can tune it for you. Doing it yourself, if you don't have prior experience, could take a long time and be very frustrating! If you know other Harley owners, ask around for recommendations and get it done by an expert. All being well an hour or so of work and possibly a few carb parts will transform your bike!
the previous owner said that if I roll the throttle to quick it will do that it does it mostly in 2nd and third gear and doesn't lag until I get about half throttle it's hard to describe but you can feel the bike take off and then it's like it hits a rev limit but again I'm only between a quarter and half throttle when it starts and if I try to roll throttle through it it backfires
I have an 03 FLSTC carbureted, with VH long shots and a SE air cleaner in my stable. It's been awhile but there's parts and settings for idle, mid and wide open throttle. Yours is most certainly off at one or all 3 phases with the parts listed and stock carb settings and jetting. No baffles doesn't allow backpressure and reduces output even further.
Agreed, jetting and tuning his air fuel ratio is his primary issue. We share the same bikes and set up parts except mine has VH baffles and was tuned. I went out to my garage to dig this up, 2005:
65.70 HP
72.99 TQ
Close to 14 air:fuel, little lean after 3.5 to end
Not a 103 (really enjoy that), but feels strong for a heavy HD.
The straight pipes cause less backpressure that exacerbates his issues under his current set up, more flow (air) with the same factory jetting amplifying a lean condition. Backpressure + or - just moves power increase from lower to upper RPM range with tuning. From low-mid to mid-high yes?
65.70 HP
72.99 TQ
