Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Carb leaking problem
Old 10-23-2016, 03:04 PM
HDsportster99's Avatar
HDsportster99
HDsportster99 is offline
Default Carb leaking problem
Im gonna be honest. Dont have much experience with carbs.
Noticed mine leaks gas, even when i shut the peacock off
Heard it was an easy fix
Old 10-23-2016, 03:53 PM
Yamaharley's Avatar
Yamaharley
Yamaharley is offline
That's your overflow. Float might be stuck, open that big center bolt and push the float up and down. Sir, I think you have a mikuni.
Old 10-23-2016, 04:19 PM
HDsportster99
Sir, you guessed right haha
Your telling me undo the big bolt and push up and down to see if its stuck
Old 10-23-2016, 04:43 PM
Yamaharley's Avatar
Yamaharley
Yes. If you ever remove the whole bottom use new screws every time as they strip out. Be careful with steel screws too as the carb is aluminium. You can also pull the main jet and pilot( I think, defiantly 2 of them) to clean with the bowl still on. Just pull that bolt thing. And fyi check that bolt to make sure it's tight every once in awhile... Don't ask.
Old 10-23-2016, 05:09 PM
HDsportster99
Okay cool. Thanks man
Old 10-23-2016, 05:37 PM
Browning, nb's Avatar
Browning, nb
Browning, nb is offline
There are lots of videos on carb cleaning on youtube. They are all very similar. Easy job.
Old 10-23-2016, 06:09 PM
HDsportster99
Will definitely check it out. Thanks
Old 10-23-2016, 06:32 PM
Yamaharley's Avatar
Yamaharley
And put a vent line on the carb, run it down and under the bike. You don't want it dumping fuel on a hot motor.
Midpegs
05-07-2019 04:21 AM
PHAT A$$
11-08-2018 10:43 AM
homiegfunk53
Exhaust System Topics
08-27-2013 02:35 PM
mustangwagz
Ironhead
08-13-2010 05:45 AM
MikeyB
04-09-2007 07:10 PM
Quick Reply: Carb leaking problem
