Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
CV Carb Broken Fuel Inlet Replacement
Old 06-29-2005, 04:08 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default CV Carb Broken Fuel Inlet Replacement
H-D has used Keihin butterfly and CV type carburetors since 1976. The same injection molded fuel inlet elbow is installed on both types. The OEM plastic elbow breaks easily, can be affected by today's fuels and has a restrictive flow rate. Creative Cycle Products fuel inlet elbow is made from brass and flows 40% more fuel. . The elbow is designed to be a direct replacement for the OEM item.
To remove the broken end that is lodged in the carb, try threading a self tapping screw or a proper sized bolt into the broken piece and pulling it out with this.
Available here http://www.creativecycles.com/
You may have to contact them by phone for the listing.
[IMG]local://upfiles/2318/375737CB8D4A4D33BD9733A847930098.gif[/IMG]
tasker26
Exhaust System Topics
03-22-2012 07:48 PM
LawDawg79
03-08-2011 08:09 AM
oil leak
08-30-2010 06:39 AM
Reaper2010
07-18-2010 07:55 AM
slowMtnRider
05-16-2006 01:36 AM
Quick Reply: CV Carb Broken Fuel Inlet Replacement
