carb leak - How to fix?
First problem with a Harley. Teach me
The gas leaks from where the red arrow is pointing..
It leaks when I pull the throttle
I'm used to carbs but on metrics.. the whole air filter hanging to the right is a new thing to me. Any reason it's leaking? Anything I can tighten down?
Your accelerator pump diaphram is bad it will ahve to be replaced its a cheap fix its under the cover directly below your leak held on by the 3 screws. im thinking around 10 bucks to fix mine.
you will need the diaphram, spring, the little oring and if possibly new screws
