Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Carb problems 2005 XLC
Old 05-12-2014, 10:37 PM
thunder7's Avatar
thunder7
thunder7 is offline
1st Gear
Default Carb problems 2005 XLC
I have been able to find many answers here to questions regarding my 2005 Sportster XLC. many thanks to those that have contributed to resolving issues that many riders experience.
Now, I have a problem that has me baffled. I have a DK Custom High flow air cleaner on my bike. I washed the bike yesterday and paid careful attention when spraying around the air cleaner and breather bolts. This morning I warmed the bike up as usual (idled fine), about 15 minutes and went to leave the house. When I shifted into gear and gave it throttle, the bike started to choke out as if it weren't getting any fuel. No matter how much throttle I gave the bike, it sputtered out and died. I got it back into the garage and parked it for the day. After work, I started the bike and it idled fine. When I gave it hard throttle, in neutral, it started backfiring through the carb and then the exhaust (a couple of times flames came out of the exhaust).
The bike was running just fine prior to washing it. All I can guess is that water got into the carb and is causing problems. If water did get into the carb, would it cause this much of a problem and how would I go about repairing the problem?
Last edited by thunder7; 05-13-2014 at 09:47 PM. Reason: Fixed problem with new plugs, fresh gas and cleaned the K&N air filter. Running fine now.
Old 05-13-2014, 09:48 PM
thunder7's Avatar
thunder7
thunder7 is offline
1st Gear
Never mind the post. A little patience, fresh spark plugs, cleaned the K&N air filter and put fresh gas in the bike today. Runs fine now.
Pfarley1
General Topics/Tech Tips
15
02-08-2020 02:07 PM
gasetter
05-04-2016 07:55 PM
ToffeeBrown
Carburetor Related
10-15-2014 01:10 PM
leadsled70
08-07-2014 08:26 AM
gerald maidment
04-11-2013 07:08 PM
Quick Reply: Carb problems 2005 XLC
