S&S Super G problem I created
So, I decided to rebuild my Super G since I haven't ridden in 2 years because of a screwed up clutch wrist I finally had surgery on. I have apparent;y screwed up something and am lost trying to find out what. When I tighten down the nut on the accelerator pump end of the throttle shaft, the shaft will not want to turn or is extremely hard to turn. When I loosen the nut it rotates easier but still seems real stiff. A friend tole me to loosen it and use Loctite, but that is not a fix. I want it right. Any suggestions? I thought it could be the new shaft so I went back with the original and no luck. Them I put the old throttle plate on the old shaft so that was all original and still the same. I have poured over this and can't seem to think what it could be. I know I got the accelerator pump actuator right and the spring is very tight on it. Where have I gone wrong???
Zedbailey
Carburetor Related
11-06-2018 10:01 PM
awstunn
05-03-2013 07:37 AM
