Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
05 sporty Revs fine but sputters on accelleration
Old 06-27-2014, 10:48 AM
1911man's Avatar
1911man
1911man is offline
Default 05 sporty Revs fine but sputters on accelleration
As the title reads I have an 05 sporty that is carbed. The bike has been sitting for about a year so today I opened up the carb and cleaned her out. Took the bowl off and cleaned and basically "pressure washed" the entire carb with carb cleaner and compressed air.
The bike fired right up but did not want to idle so I tried giving it throttle and it just kept dieing. Finally I figure out if I would just rev it back and forth instead of holding the throttle open it that it would stay alive and finally it warmed up enough to idle.
Well it is idling like crap and if I try to slowing accelerate the throttle the bike stumbles and backfires out of the carb. When I just rev it by flicking my wrist but not holding it the bike sounds fine and doesnt stumble.
Any ideas? Help is greatly appreciated.
Old 07-21-2014, 10:58 PM
nashspu's Avatar
nashspu
nashspu is offline
I am having a similar problem with my wife's 05 Sportster 1200. I didn't put Sta-bil in last fall and am having some issues with that first little twist of the throttle. A little cough and sputter, but at anything over idle all is fine. Normal power and acceleration. Drained the gas and changed plugs and it got a little better yet. Hoping that just some fuel system cleaner and miles will make it come out of it.
Old 07-23-2014, 12:48 AM
blakeusa's Avatar
blakeusa
blakeusa is offline
Check for any error codes using your speedo
Also have been reading a lot about the Crank Position Sensors and a high failure rate on these bikes. Its a easy fix but the part is $60 bucks. Worth keeping a spare.
Rough idle, pops, staling, hard to keep running etc.
Not everyone gets codes either.
Old 07-23-2014, 10:10 AM
rh8234's Avatar
rh8234
rh8234 is offline
Same thing happened with my wife's '06 carbed Sporty. It was the crank position sensor, and I did not get any codes.
Old 07-25-2014, 01:17 AM
blakeusa's Avatar
blakeusa
blakeusa is offline
I have changed my Crank Position Sensor and I still have the pops and backfire out the carb.
Just took carb and jets out - all looks clean but cleaning again. Running a 175 main and 45 low jet which should be good for my bike.
Also replaced all three intake gaskets and there are no leaks.
The only thing I saw was with the AC off on accel there was no gas spray until I went to a much higher rev. Dont know if that is normal.
ClodeV
07-07-2014 08:28 PM
1911man
07-06-2014 09:14 AM
SOCALHD
05-15-2014 01:44 AM
dirty1east
Exhaust System Topics
11-16-2009 07:55 PM
fastjoe
10-03-2009 01:01 AM
Quick Reply: 05 sporty Revs fine but sputters on accelleration
