Classic All 'historic' bikes.
1973 Harley Davidson SX125
Old 12-06-2010, 03:03 AM
michael121's Avatar
michael121
michael121 is offline
Stage II
Default 1973 Harley Davidson SX125
Hi guys,
I have a 1973 Harley Davidson SX125. Its a 2 stroke bike and im in the process of having it reconditioned. It was in pretty good condition to begin with. It's been sitting around for quite some time and im at the stage of installing the carburretor. I've been told i need a new one as it's not working properly: The needle valve is not sealing properly and shutting the fuel off. Ive managed to source a new valve but still faulty. No-one can work out what the problem is. So i am after a new carb. The exact model number is: Dellorto SH2-24. Does anyone know where i could source one from or does anyone have one ? If i am posting in the wrong thread then let me know, its my first post. Any help would be greatly appreciated! Cheers, Mike.
Old 12-09-2010, 10:34 AM
d_slat's Avatar
d_slat
d_slat is online now
If I were you I'd try to get the old carb to work yet. If it is the inlet needle leaking, there should be a way to fix it. I've had several that didn't want to seat, even with a new needle, and this what usually fixed them:
Take an old all metal needle (w/o viton tip) and put some valve lapping compound or other light paste abrasive on it (i've even used toothpaste, but it gums up and can be a pain to clean out later on) stick it up in the hole and spin. It will lap the seat and clean up any corrosion, giving the new needle a good surface to seal against. I actually epoxied a needle to the end of a drill driver bit and I use my cordless drill to to it.
Good luck
Old 12-09-2010, 05:32 PM
panz4ever's Avatar
panz4ever
panz4ever is online now
Received 3,200 Likes on 1,477 Posts
Hades02
Carburetor Related
12-29-2016 05:59 PM
michael121
Exhaust System Topics
07-24-2014 11:34 AM
Wakko47
EVO
09-03-2012 06:47 PM
scottwilliamson
02-22-2011 08:05 PM
crasher
10-09-2005 07:13 PM
Quick Reply: 1973 Harley Davidson SX125
