First build rear brakes
Old 09-28-2014, 11:57 PM
LoBoT's Avatar
LoBoT
LoBoT is offline
Default First build rear brakes
Workin on my first build and figuring out the rear brake setup. Any reason a year 2000 Sporster 883 master cylinder wouldn't power a 1992 FXR rear disk brake system? If it'll work I can handle fitment issues. Thanks in advance.
Pic of work so far attached.
Old 10-01-2014, 02:17 PM
tomt's Avatar
tomt
tomt is offline
I think the master cylinder is for a four piston caliper. Is the 92 FXR a two piston? Don't know much about FXRs. Nice looking bike so far.
Old 10-14-2014, 02:55 PM
LoBoT's Avatar
LoBoT
LoBoT is offline
I ended up with a master from a 2002 sportster 1200. It's for a 4 piston set up and the FXR is a single. The folks at Barnett Harley say "any ole master will do..." We'll see. I'm thinkin a 4 piston would need more juice. It may make a single piston rear brake a bit touchy. The bracket I'm building is a bolt-on to existing holes so I can always back up and re-punt.
Old 11-21-2015, 10:11 AM
LoBoT's Avatar
LoBoT
LoBoT is offline
Well, 20 months later and the project bike is on the road. Stock 80 ci EVO, Paughco frame and front. 16 in rims and lots of Mig weld to fits. Paint by Bearden's. It rides like a I'd hoped and nuthin has rattled off so far...
Attached Thumbnails First build rear brakes-project-a1.jpg   First build rear brakes-project-a3.jpg   First build rear brakes-project-a5.jpg   First build rear brakes-project-as-is.jpg
Old 11-28-2015, 12:44 PM
graultytc88's Avatar
graultytc88
graultytc88 is offline
Nice work! No better feeling than riding something you built yourself.
Who's fork is that?
What did you end up with on that rear brake?
Old 12-01-2015, 02:14 PM
LoBoT's Avatar
LoBoT
LoBoT is offline
Who's fork is that?
Thanks. I'm having hoot. Forks are from Paughco. As is the frame. (very pleased with the quality) Rear brake is an OEM single piston from a 92 FXR pushed by a 2002 Sportster master cylinder. It all links to a Wyatt forward mount floorboard kit. I only had to shorten the connecting rod between the pedal and master cylinder. No adjustment to the mechanical advantage ratios. They give good response as is.
Old 12-24-2015, 04:32 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Amazing build. Kudos.
Old 12-29-2015, 10:41 PM
Katienadine's Avatar
Katienadine
Katienadine is offline
Very cool, unique ride.
Old 01-01-2016, 02:45 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,919 Likes on 17,474 Posts
Don't over think it the bore size of the master cylinder is all that matters and the rears are all the same, getting into 4 verses 1 piston and MC sizes is a front brake thing. Built lots of custom systems & bikes over the years.
jeffrob07
EVO
06-02-2017 03:34 PM
dirtbag1
EVO
10-22-2013 09:41 AM
JefFLH
Wheels/Tires
06-29-2013 05:51 PM
cornishbob
EVO
09-08-2008 08:14 AM
Quick Reply: First build rear brakes
