1972 FLH Fat Boy?
RE: 1972 FLH Fat Boy?
Why not if you can get the chain to fit/clear. \\; I looked &\\; bought the 07 Fatboy front end to put it on a friends 67 FL, basically the same bike. \\; You can upgrade the brake &\\; make a new bracket for the brake with spacer. \\; I would suggest doing a swing arm / brake bracket clamp around in place of a link as you have. \\; It is much cleaner. I believe the rear of a 1972 was the first year of the square tubing replacing the round one and doing away with the drum brake &\\; replacing it with the banana brake. \\; Am I correct as it has been many years since I looked @ a 1972?
