Anyone recommend a good way to clean fuels stains? Previous owner left the fuel on for the winter and it leaked out and all over the motor causing a yellow stain.
If the stain is on the aluminum motor casing you could use some Mothers aluminum polish to take the stain out. might take a bit of work but the end result will look pretty good. Mothers also sells a variety of power buffer pads which attach to your power drill to make the work quite a bit easier. This stuff is available at big box stores as well as most auto part stores....Good luck
