Best wax for Harley Paint
Old 04-22-2010, 04:28 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Originally Posted by Timmy-bob
I use turtle wax ICE. Can use on anything becuse it is a synthetic. will not leave white marks. You can even wax rubber! Trick is to put it on with a wet pad and just keep getting lighter with your touch. (think of it like spit shinnig a boot.) I have vivid black and it dose great getting rid of micro abrasions in the paint. (fine line sratches, etc) I hope this helps and be safe.
Ditto - ICE works great & doesn't leave behind the white powdery mess. My bike's Vivid Black too and it really brings out the shine...
Old 04-22-2010, 04:40 PM
Deuce Bigelow's Avatar
Deuce Bigelow
Deuce Bigelow is offline
Zaino will not leave white marks on black rubber either...
but whatever you choose to use, just use it OFTEN!
and like has been said in previous posts.... It's ALL in the PREP!
wax alone isn't going to make the surface look like a mirror.
Old 04-22-2010, 04:55 PM
izzy's Avatar
izzy
izzy is offline
i use meguiar's tech wax 2.0. Cheap enough, easy to use, and a little goes a long way. Very pleased with the results.
Old 04-22-2010, 07:09 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Originally Posted by UltraKla$$ic
Actually you have to "prep" the surface correctly in order to TRULY get that slick as glass look, anything less would be a "filler". Then apply the Zaino Z2, Z6, and Z8 for long lasting protection as to not disappoint Ken, or a good Carnuba Wax.
Damn man do you ever have time to ride that thing?
Old 04-22-2010, 07:34 PM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
+1 I use all their ICE products and they work very well.
Old 04-22-2010, 07:48 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
The Only thing I use is Lemon Pledge. No Muss or Fuss. Works GREAT and cheap too!
Old 04-22-2010, 08:35 PM
Ronjo's Avatar
Ronjo
Ronjo is offline
(Protect All) Sold at Walmart in the RV section. Goes on everything from plastic to paint to seat without leaving the dreaded white crap. Only thing Mustang recommends for their seats. has UV blocker and loaded with carnauba wax. As the bottle says: polishes, waxes, treats, protects. Best kept secret out there and have been using it for years.
fasteddiee122's Avatar
fasteddiee122
fasteddiee122 is offline
astro shield !! good luck trying to find some tho company went out of business , 100 bucks a gallon !! great stuff tho ...
Old 04-22-2010, 08:44 PM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
I use a variety of waxes but for the in between touch ups Lucas Slick Mist has worked GREAT!
Old 04-22-2010, 08:48 PM
moosh's Avatar
moosh
moosh is offline
Zymol..hard to believe you can find anything better
Quick Reply: Best wax for Harley Paint
