Wax off Denim Paint
Wax off Denim Paint
How to get wax off Denim Paint
I tried Windex, Denim paint cleaner, washing with Dawn and short of using PigSpit or sanding the wax off, this finally worked.
Material needed:
Professional paint shop grade Wax and Grease Remover
HD Denim Paint Cleaner
Roll of paper towels
1. First keep 1 paper towel in your hand and one nearby
2. Wet the first paper towel with Wax and Grease Remover. Don't be shy.
3. Wipe it heavy and wet onto the surface that your cleaning and scrub the crap out of the length of the fender or tank that your cleaning back and forth keeping the whole area wet and making sure to scrub evenly on all areas.
4. Before it dries because it will quickly leave a hazy residue, quickly grab your second paper towel and wipe the majority of the Wax and Grease Remover off in one fluid motion from one end to the other. The fender will still be somewhat wet and at this point, so you can let it evaporate.
5. If the finish dries with a haze, repeat steps 1 through 4.
6. Grab 2 new paper towels and spray down the fender with the HD Denim Cleaner.
7. Wipe back and forth again with the first paper towel making sure not to let it dry.
8. In one sweeping motion use the second paper towel to quickly wipe the fender down and then let the excess evaporate.
9. This should do it. Make sure to use long fluid motions and keep it wet like you would your lady. You don't want it to dry and don't want to stop in the middle of a stroke. Nobody will be happy in the end.
Big thanks to Loungelizard on this as we both worked on it together and he talked me off the ledge!!! LOL
Material needed:
fmgsr
10-23-2015 02:19 PM
