"88 fxrs connector at headlight wires loose
Hello. I am having turn signal issues and I saw a post about it but they were not able to upload the schematic on the site. Does anyone have the wiring schematic for the 12 pin connector that is at the headlight? There are 2 wires at the connector and they both show 12 volts. But I cannot see where they should be connected. Please help! I'm trying to get to dinner. And thanks in advance!
Here is the connector. You can see the 2 wires next to each other that are loose. They both had heat shrink on them. So I am assuming they had terminals crimped on them but not sure. They both show 12 volts when key is on.
you can see the 2 wires that are in question. They both had heat shrink on them as if they had terminals crimped but not sure
khansmith
09-01-2007 06:55 AM
