**Superchips Vigilante EZ Review**
#91
Craigffb:
The error code reads P0289, which I can't seem to find online or elsewhere. The only modification I've ever made to the bike is a set of Screamin' Eagle slip-ons, HD stock #80679-12. The code won't clear. Now I'm a bit bewildered, as the bike has never run better.
Edit: I should add that I made no changes to the tuning when I installed the slip-ons.
Sorry about my lack of knowledge, but my last two bikes were a 1968 XLCH and a 1980 Fat Bob, so this stuff is entirely new to me.
#92
Craigffb:
https://www.hdforums.com/forum/dyna-...ror-codes.html
#94
Craigffb:
Thanks for the link to blueangel's post. The bike is showing error code P 1655, which indicates a faulty solenoid in the ACR system. Well, now, my engine is 96ci; I ain't got no ACR system.
I'm pretty relieved; I thought I might have done something unhealthy to the fuel injection. I still can't clear the code or get the "check engine" light off, though. Once again, the bike runs better than it ever has, so I'm not too bothered.
I guess the tuner thinks I've got a 103ci engine?
#95
Craigffb:
My suggestion to you would be to load the factory tune back into the bike and see if the DTC clears. The fact that the bike is showing one code and the tuner is showing another would be troubling to me. If the code clears by loading the stock tune back in the bike you need to call Superchips and give them all the details.
#97
However, I found this thread:
https://www.hdforums.com/forum/touri...e-on-96ci.html
This explains quite a bit. I'll give them a ring and ask them to send me a map that doesn't turn the ACR on. Looks like a simple fix. Appreciate all the info; I'll holler back later.
Edit: Oh, yeah, I forgot to mention that I tried flashing the bike back to factory specs; the ACR stays on anyway. No big deal, I'm just glad I didn't screw anything up.
BTW, error code P 0289 doesn't seem to exist.
#98
Yep. It said that there were no updates.
#99
I had one and thought it was a good flash unit. I already had the dealer flash and a TFI. I turned off the TFI and reflashed with the Vigilante and the bike did run better than the original setup. The reason I didn't keep it was I already had invested already plus I plan on selling this spring. I never did try the Vigilante and the TFI together though. Wish I had.
#100
