Master rear brake resevoir cap
Old 09-22-2014, 02:03 PM
rogersachs's Avatar
rogersachs
rogersachs is offline
Question Master rear brake resevoir cap
I am going to change my brake pads on my 2013 Street Bob. Placing Lyndall Golds.
How do you get at, and remove the rear resevoir cap. I can hardly get my hand on it. It appears to screw off???
How do you add dot 4 to it once you get the thing off? Could use an eye dropper?
I do have a lift and a 2013 service manual and replaced the pads on my previous V Rod with no problems, but with abs and pad spring tabs it seems a little trickier.
Also are there any video clips of how to change the pads on the newer Dyna's with spring tabs .
Thanks,
Roger
rogersachs
12-12-2014 08:22 AM
busboyblues
04-04-2012 12:18 PM
clarsen2020
Wheels/Tires
07-22-2010 07:32 AM
dgretz
09-04-2007 03:41 PM
Beemervet
07-06-2006 03:08 PM
Quick Reply: Master rear brake resevoir cap
