BAD&G solo bag install question
Old 10-15-2014, 08:07 PM
Navarre's Avatar
Navarre
Navarre is online now
Default BAD&G solo bag install question
I have just ordered a DL01BL solo bag from BAD&G. I like the solo bag look and the great reviews the bags received on this Forum were a big help. I know that it has leather straps that you wrap around the chrome fender trim. The strap closest to the seat looks to be pretty easy since there is a nice gap in between the trim and the fender. The other side not so much. My question is when you loosen the trim, did you put a permanent spacer in between the trim and fender to create a gap or just thread the strap through and tighten? If so, does the leather strap degrade or get cut since the trim is clamped against the fender?
Thanks!
Navarre
Old 10-15-2014, 08:19 PM
JMC22's Avatar
JMC22
JMC22 is offline
Loosen up the bolts for the trim cover, slide the leather straps thru and then snug the bolts for the trim cover back down.
The leather strap will not degrade any faster then the others - you'll be fine.
Old 10-16-2014, 07:12 AM
pab3rd's Avatar
pab3rd
pab3rd is offline
Ditto
Old 10-16-2014, 05:10 PM
Navarre's Avatar
Navarre
Thanks for the replies guys! Leaving out the spacer will make it much easier.
Thanks again!
Navarre
Scooby1426
10-14-2016 04:40 PM
Hogpro
05-29-2013 06:38 PM
mikebaby
05-03-2012 08:03 PM
Hog Yild
10-15-2010 07:11 AM
HuskerPower
04-03-2009 08:01 PM
Quick Reply: BAD&G solo bag install question
