Down side to Tank Lifts?
Did a lift on my Sporty, I know different than a dyna. But I definetly lost some mileage and the reserve is less than before about half as much. got caugh trying to make it one more exit which I would have made pre-lift. Got to be reminded how much fun it is to push a bike for a mile. Still looks great but it is a possible side effect.
I think it makes the bike look 100 times better, but on a wide glide, i had to rotate my bars forward and adjust the brake and clutch levers. it makes the handlebars feel a little uncomfortable compared to the stock position as it makes the angle bend more rearward than down which is unnatural bend for the wrist. I had to do this or the throttle cable was rubbing the tank when turned to the right.
also, on a wide glide, the fork clamps on the upper triple tree misses the tank about 1/8 of an inch at full turn with a 2" lift. if i ever drop the bike, im sure there will be enough force to make the triple tree punch into the tank.
with all that said, id do it again.
The reason most people do a tank lift is for the looks. When we first started designing ours, we did so for 3 reasons:
1. The looks... It just flows better with the lines of the backbone of the bike to be lifted.
2. Ease of cleaning.... With more of the rockers exposed, it is now easier to clean them.
3. Air Flow... It makes for better Air Flow over the motor.
After doing testing, it was noticed that since more air now flows between the tank and motor, in some cases it can reduce the buffeting. This is not what they are designed for, more of a "side affect".
There is tons of information on tank lifts in this thread:
CLICK ME
In that thread it also addresses the fuel gauge and usable fuel capacity when you do a tank lift.
CLICK ME
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
CLICK ME
CLICK ME
the fuel gauge is an easy fix if you want to even be bothered
"P"
Even when my bike was completely stock the light comes on early. I'm pretty sure they do this so you don't run out. When the miles to empty says "LO", I still have about 1 gallon left. This is your reserve. The analog gauge (which most vehicles have not just bikes) is never precise.
