DIY Heim Joint Shift Linkage
heim joints here $2.95 ea
http://www.ebay.com/itm/ECON-5-16-x-...-/271595476180
great upgrade BTW thanks for the write up
This may not be the case if you have a newer Dyna. On my Bob, the stock rod wasn't threaded and it was attached using the ball and cup style joint. I planned on using the stock rod and when I found this out, I went out and made my own.
For any of you that want to changeover to Heim joints, forum sponsor D&K Custom Products can provide the correct Heim Joints with jam nuts for $19.95 and shipping. Its fast and easy...just remove the stock parts and add these. They work with the stock shift rod, but I eventually want to replace it with stainless steel.
You will need to pick up the 5/16 X 24" bolts and cap nuts at a local hardware store.
I bought the DK mid controls link for mine. And I have to say, for anybody thinking of getting one or making their own... DO IT. With 3500mi on my stock link after I took it off I checked it out, it actually had a tiny bit of play and I could see it failing. With the new heim joint and link I have to say it not only has smoother linkage travel but just shifting it feels much more solid, like it should. My heims don't flop around or push to one side when in use either.
Thanks for the comments guys and gals if you're out there. I don't plan on painting the joints. I like the raw mechanical look of them. If I did paint, I would take a round sticker and place it over each side to keep paint out.
