Short guys, air cleaners that get out of the way of your knee?
I'm 5'8" and found the forward controls on my 2007 FXDWG a little bit of a reach. I installed the reduced reach kit ( which brings the controls back about an inch and out about an inch. This spreads your legs out a little bit giving you more room on the air cleaner and horn. I'm running a S&S air cleaner. The HD part number is 50700005.
If you aren't worried about dropping some coin Roland Sands makes the Slant air cleaner specifically cut for knee clearance. Also Performance machines has a lo-pro air cleaner
RSD Slant
http://www.rolandsands.com/products/...it-carbon-ops-
Performance Machine MAXHP
http://www.performancemachine.com/mo...rs/MAX-HP.aspx
RSD Slant
One question - looks like you went with the breather bolts. I did the kit with the tubes down to a filter, but I much prefer the look of the straight bolt breathers. So - are you getting any oil spew from them? I think I might just go to the bolts as they look better. I can probably wipe off any oil....
Received 3,940 Likes
That looks great. I'm biased though.
There are things one can do to limit how much oil carry over there is (see link below) but on the Twin Cams (especially the 103's) there is such a margin in HD MFG tolerances and so much variation in how each person rides, it is just not possible to know if the Breather Bolts will spray any significant oil or not, without actually trying them.
This does NOT hold true for Sportsters or the TC 88's and most TC 96's. Those will not put out any significant oil if the bike not in need of repair.
https://www.hdforums.com/forum/oil-a...f-my-bike.html
