pulley torque spec?
Old 10-25-2014, 01:33 PM
Jesse_81's Avatar
Jesse_81
Jesse_81 is offline
Default pulley torque spec?
Anyone have the torque specs for the rear pulley? Mag off an '08 if that matters.
Old 10-25-2014, 01:39 PM
fskitch's Avatar
fskitch
fskitch is offline
See HD Pilot's post below for correct torque setting
Last edited by fskitch; 10-25-2014 at 02:02 PM. Reason: HD Service Bulletin M-1219
Old 10-25-2014, 01:40 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Should be using new HD screws that come with the pre-applied threadlocker. If using new aftermarket screws, then 2-3 drops of red Loctite 262. Should also clean out the threads in wheel hub.
From my 2012 HD SM: initial torque of 60 ft-lbs then back off 180 degrees, final torque of 77-83 ft-lbs.
Old 10-25-2014, 01:44 PM
fskitch's Avatar
fskitch
fskitch is offline
I should mention my specs came from an '07 SM.
Old 10-25-2014, 01:46 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Originally Posted by fskitch
55-65 ft/lbs. Always use new bolts (screws).
I am pretty certain this is old info. HD Service Bulletin M-1219 dated April 15, 2008 states the specs I mentioned above for all 1999 and later HD Models except VRSC.
Old 10-25-2014, 01:53 PM
fskitch's Avatar
fskitch
fskitch is offline
Thanks--I didn't know that, I will note that in my SM.
Jeff Wetter
Wheels/Tires
07-03-2017 04:54 PM
PurpleShark
03-08-2017 10:56 AM
dan conner
12-12-2011 07:55 AM
sjp3003
General Topics/Tech Tips
06-18-2011 12:18 AM
car5car
Exhaust System Topics
76
12-29-2009 12:20 PM
Quick Reply: pulley torque spec?
