fuel inj or carbs which performs better?
1 Post
Well my 2006 has FI. I bitched up a storm on the forums how bad i thought it sucked as for performance. Only thing i did like was the ease of starting the bike with out using a choke. But then i bought a Power Vision tuner and played with it some. Now i will say i kind of like the EFI set up although i am running the bike in open loop all the time now and i aint no where close to the factory settings on my EFI and timing either.
I'm a carb man from way back but am pretty excited about the more advanced EFI where you can create a custom map for fueling and timing based upon RPM, engine load and throttle position and then even by gear.
Sure, gaining a solid, working understanding of EFI and adapting it to your app may not be quick, cheap and easy... but then again neither was properly dialing in a Weber 45DCOE.
As for the HD carb, the late CV design is pretty easy to dial in with excellent all around performance for normal applications. www.CV-Performance.com has about everything you need to economically maximize the HD CV carb.
