Place to lift bike with Pitbull rear stand?
OK, so I have a Pitbull rear stand that Ive used on several bikes. It has a reversible top for lifting via spindles or rear swingarm.
I cant use the swingarm because the exhaust is too long and doesnt give enough support for the Pitbull.
So, I was wondering if any forum members out there knew of spindles I could attach to the rear wheel so that I can use the Pitbull stand that way. Or if I could put a solid metal bar through the hub?
Any opinions are welcome. Im trying to put the bike away for the winter and lift the rear off the ground so it doesnt flatspot.
I bought that once. The bike was so unstable on it that I returned it same day. Im trying to use stuff I already have and not spend more money. Its just to lift the rear wheel, not the whole bike. Maybe Im just asking for the impossible.
I was thinking I could just put some pipe through the rear hub and lift it that way.
I am sorry but I am confused here.
From what I read you are only wanting to have the rear tire off the ground so it won't have a flat spot form storing the bike.
If this is correct why not just put the bike on the lift and have both tires off the ground. I mean if your concerned about a flat spot on the rear tire what about the front tire. I have never had a flat spot on any of my tire from sitting. If it does have one it's gone in a 100 miles or so.
Maybe I'm just getting old and confused. I have 5 bikes and only ride 2 of em in the winter months and have never experienced any flat spots as of yet.
If the front tire is on a parking chock or on the ground it is still going to have the weight on the front when you raise the rear off the ground. When the rear is higher the weight is transferred to the front.
Having it on a chock will only have front off the ground and is on the metal chock instead.
your best bet is to put the bike on the jack. I have stands that I have made. I raise the bike up on the jack then slide the stand under it then remove the jack. You couldn't knock the bike off of it if you wanted to. It is more stable than any pitbull jack could be.
I think you are just overly concerned over nothing.
drspencer
12-26-2011 04:59 PM
