Powder coating during motor work... Need opinions
I wanted to do the jugs and heads black but with black rocker boxes I was thinking that it would just look like a big blob of black, especially with black pr tubes. Then I thought black jugs, gray heads and black rocker boxes but the gray/ black/ gray/ black might not look right either. The black heads and jugs would look great if I was going to run chrome rocker boxes but I don't want any chrome.
I think a satin would be best and if it were me I would do the rocker boxes, pushrod tubes, tappet blocks, cam cover with a black ignition cover ( factory or aftermarket ), transmission end and top covers. I would leave the jugs and heads as is. The black tubes and r/b covers would play off those I think. The outer primary would look good black, but would look better if you can swing doing the inner also ( ask me how I know lol ). And again, just my opinion.
I just picked up my PR tubes and lifter blocks and they look killer! I had them done like most my other parts in a black texture like the block and tranny.
I had them protect the mating services so they are smooth against the seal surfaces.
So, if there was a question to answer, I say, by all means, Go for it
Oh yeah, don't forget the swing arm nut cover if you haven't doused it yet with PC!
I'm getting ready to start my winter motor build and I'm going to send some parts to powder. I'm going to powder the rocker boxes, pushrod tubes and tappet blocks, cam cover, side and top tranny covers and air cleaner cover again if necessary. So here's where I can't make up my mind. Should I powder the parts gloss black or semi gloss like the rest of the bike? I was going to do black jugs and cylinders but I think with black rocker boxes it would be too much black. Should I do the primary or leave it gray? I'm going to vht the pipe for now and get it powdered down the road after I have it twisted.
