Calling all Harley Electrical GURU's
Ok.... I decided to relocate my speedo and my ignition switch on my 2013 FXDB street bob, I have modded my stock dash and built a custom mount for the speedo and new toggle switch for the ignition switch. I have run into a problem that is confusing to me. I couldn't figure out how the ignition switch was wired to work, so I decided to open the switch, take it apart and see if I can reverse engineer it, I figured out that one of the two wires is a constant ground and the other is my positive, i was able to open the switch enough to find a circuit board containing three very small rectangle things. two of them say 101 on them and the other says 841...or something like that. i removed the 101 thing and placed between my constant ground and my positive wire and it turned the bike on, however the bike only turns on when the 101 thing is placed inside the circuit. when i put the 841 thing in the circuit it turns on my accessorie.....what are these things....my best bet is that they are resistors, but why???? and if so what is value of the resistor... the whole point of this is so that I can put the ignition switch on a simple toggle on off switch. please if anyone can help I would appreciate it, the oem switch is done for so I need to figure this out to have an operating bike
How are your soldering skills?
It is likely something that modifies the power that the ECM see when power is applied. The easiest and simplest solution, is indeed a resistor, as mentioned.
If you can solder, I would solder each one inline, and use heat shrink over it. Get a SPDT toggle switch, one position would be ACC, one OFF, and the other ON.
If you can use a multimeter, measure those, and get their resistance. Get those in a resistor with the proper leads, and resistance. Test it then, to be sure that it's the proper part for the function. Then, hardwire it.
Sorry if I'm all over the place, haven't had my coffee yet,
Very able to be solved.
Chase
Chase
I think you have what is called a resistor ladder.
Basically it is a series of resistors that tell the ECU the switch position. It so that you can have 2 wires that indicate several switch positions based on their resistance. The actual switching of power is done by the ECU
You need to make sure that the relevant resistors are activated by the switch position to mimic the original switch. As mentioned above
Resistor ladders are common in the Auto industry where you have complex switching but want to cut down on the number of wires/connector pins.
Joe_G
12-24-2021 09:58 AM
markuhen
07-04-2006 06:11 PM
