Correct engine displacement when using overbore pistons?
Old 12-07-2014, 09:38 PM
jmb79's Avatar
jmb79
jmb79 is offline
Default Correct engine displacement when using overbore pistons?
I am rebuilding my 95" engine to a 106" using the S&S stroker kit. For those who don't know, the S&S 106" stroker kit replaces the 4" stroke oem flywheel assembly with a 4 1/2" stroke flywheel assembly, and uses 3.875 bore pistons, which is the same piston diameter as the 95" big bore I already have.
So, this afternoon I was musing about the following: to get the best fit with the new pistons that are part of the 106" kit, I had my cylinders re-machined and used +.05" overbore pistons. Now, as we all know, the formula for computing engine displacement on a two cylinder engine is Bore x Bore x Stroke X 1.5708 = Displacement. Thus, without the overbore pistons, the equation is 3.875 x 3.875 x 4.5 x 1.5708 = 106.13944 cu. in. (aka 106). However, with the +.05" overbore pistons, the equation is 3.925 x 3.925 x 4.5 x 1.5708 = 108.8962, which is, after rounding, 109".
I'm guessing that using overbore pistons is fairly common, especially on bikes that have had previous work. However, you never hear such builds being referred to by the larger displacement figure... or do you...?
There's no real point to this post, just interested in thoughts or comments any of you might have.
Old 12-07-2014, 09:51 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,030 Likes on 651 Posts
I have when they are evos. Like a 84 or 85 inch. Well, the 98 inch Twincam is just a over bore 95
Old 12-07-2014, 09:54 PM
ottawaair's Avatar
ottawaair
ottawaair is offline
Can you bore your 95" cylinders another .050" ??? I don't think that there is enough meat on the cylinder skirts.
Are you doing a .005" clean up pass ??
Old 12-07-2014, 10:19 PM
jmb79's Avatar
jmb79
jmb79 is offline
Taking an 88" to a 98" is pretty common and that requires a 3.938" bore. So, yes, .05" overbore on a nominal 95" build is fine.
Old 12-08-2014, 06:00 AM
vdop's Avatar
vdop
vdop is offline
Do they even make pistons in that 3.925 bore for the 4-1/2 stroke? You very rarely hear of people running that oddball long stroke 106 kit which is probably why you don't hear about people making them a 108 or 109. Why not just go 4-3/8 107"?
Old 12-08-2014, 08:10 AM
jmb79's Avatar
jmb79
jmb79 is offline
Yes, S&S sells the 4.5" stroke flywheel assembly and the matching 3.875" pistons for a 106" stroker build. The S&S pistons are available in 3.875" as well as .05", .10" and .20" overbore.
http://www.sscycle.com/product/1999-...it-p24019.html
http://www.sscycle.com/product/1999-...8B-p24042.html
The reason I didn't go 107" (i.e. 4 3/8" stroke plus 98" pistons) is that I will probably add a turbo in the spring and don't want to go too thin on the cylinder walls as that will require the use of head gaskets that don't have a lot of material between the stud hole and cylinder bore.
Old 12-08-2014, 11:41 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,809 Likes on 3,314 Posts
Default another decimal............ .005
Dude you need another decimal point it's 5 thousandths or .005, 10 thousandths or .010 etc. .10 would be 10 hundredths and no one makes pistons over in those sizes....
Old 12-08-2014, 12:09 PM
jmb79's Avatar
jmb79
jmb79 is offline
Sheesh! You are absolutely right. That makes so much more sense, and explains why the size increase seemed so much for just an overbore piston.
And my apologies to ottawaair. You were correct also. I swear I read and re-read the numbers several times and still saw .05 instead of .005.
As a side note, I really need to get some reading glasses. I've been putting it off for over a year now but this mistake proves how much I need them. Thanks for setting me straight.
Mattbastard
Engine Mechanical Topics
04-24-2019 06:08 AM
hoozdis
04-10-2016 08:18 PM
pipercolt
06-08-2014 05:14 PM
mountian man
12-29-2010 02:01 PM
redrubicon2004
Exhaust System Topics
11-29-2008 10:17 PM
Quick Reply: Correct engine displacement when using overbore pistons?
