what's everyone's winter mod plans
#41
#42
RB and D&D are the top power makers... If you have the RB I definitly wouldn't be changing it...plus the RB weights less. I would say that's the major downside to the D&D.
If you decide to get a Fatcat send me a PM cause I might be interested in trying out the RB. I also have the standard baffle for the D&D incase you get the pipe with the performance baffle and want to have both to see which does better during your dyno.
Congrats! Engine work is a major change that does a night a day on your ride.
#43
660s are big cams for a 107", I kinda wish I had gone with a tad smaller cam than the 590s. From what I have learned and experienced, 10.5 compression is about as low as you want to go with 590s and looking at the 660s, probably the same. They would both run better at 10.8:1 up to 11.0:1, but now you have to deal with a high compression build - need a great tune. Good luck, and have fun with the build!
#44
Will let you know about the exhaust change, my tuner guy believes the RB is holding back the bottom end torque with my current set up on the 96 and thinks I will benefit from going to a fatcat on the new build. I am looking to shift the torque curve to the lower rpms but not sure I want to do the build and spend Dyno time on the RB and find out it is still not picking up the low end torque that I want to see. The fatcat will make the bottom end power for sure, my tuner guy has endless Dyno charts to prove it. i am curious to see how the RB will perform with the build as well and if I can work out something with my tuner I may end up keeping it, I love the look of the RB and would like to keep it if I can get some more bottom end torque. I will let you know if I put it up for sale.
#45
