What did you do to your Dyna today?
#691
Jerzee customs
They're certainly nice to have Every HD I've ever owned ends up with one, it's piece of mind always knowing what your oil pressure is doing. The Jerzee Customs oil pressure kit is JC-9100TC and is very nicely made and the install isn't too difficult. My right thigh does touch the gauge trim cover but it's not at all distracting or anything like hitting your knee on the A/C and it's pretty cool to be able to glance down and see that 40 PSI on the gauge as you're rolling down the road
If you never installed one before I can post up a quick how-to and a few tricks...
http://www.jerzeecustoms.com/HDProducts.htm
#692
I recently moved my turn signals and added quick release bags using easy brackets. I really like the brackets and it was a pretty quick and simple install.
#693
Looking Good...
#694
Covered It Up, Due to a rainy day ahead
Hoping for some sunshine tomorrow
#696
The Jerzee Customs kit does come with instructions but a couple of things I've found as well after installing quite a few of these little critters. First, a 15/16" socket is really the only good way to remove the oil pressure switch without tearing it up. Depending on the style of exhaust you've got you may need to go through a few gymnastics to remove the switch and reinstall the adapter/switch back in to the case.
When you remove the oil pressure switch you will have some oil leakage from the case so be ready for that. Don't use teflon tape on the adapter or switch threads, use pipe dope paste instead to prevent any leaks. It's much easier to install the oil pressure switch into the adapter first, then install the adapter/switch back in the engine case. The trick with the adapter is you want the threading for the oil pressure line at the top or nearly so. Don't over-tighten the adapter to get the oil line threading to the top, you'll run the risk of tearing out the threading in the case and that would be **bad**, it only needs to be a snug/tight so if it's not tightening up with the oil line threading at the top remove the adapter and rotate the adapter so it's catching the case threading in a new position, it may take a few tries to get it both tight and the threading at the top but it will align, just don't go nuts and over-tighten it to bring the oil line threading to the top.
When you remove the rocker cover screw closer to the intake it may run in to the fuel tank before you can get it out, if so you might need to lift the rear of the tank to get enough clearance. The last thing you do is install the oil pressure line in to the adapter, as the fitting gets tight the oil line will want to twist, hold on to the oil line as you tighten the fitting so the line doesn't look like a pretzel when you're done, again it might take a few tries to get the fitting tight and have the oil line positioned like you want it.
Tazze (03-21-2021)
#697
Put my '07 Low Rider 'Street Bob' up for sale for $7,475 on Monday. Have a showing tomorrow. At 5'4" with a 27" inseam I just couldn't get truely comfortable with the little extra size and weight over the 1200S Sportster I came out of.
#699
Few simple mods
Only had this bike a couple weeks. Installed new derby cover, timing cover, and leather bag on forks. This weekend V&H Big Radius, RSD air cleaner, and Fuelpak. Like always I have more ideas than $$$$. But I'm having a blast. Love my FatBob.
#700
The fork bag looks really nice. Had mine since '11, the buckles are rusted, and has permanent bug gut stains on it. Hope yours enjoys the same outcome a few years from now. FWIW, your model and the Softail Slim are the best lookin' bikes MoCo builds. tp
