2010 to 2007 Street Bob front wheel swap question
Does anyone know if I can mount a 2010 Street Bob wheel (with 25mm bearings, bearing sleeve and brake disk) to a 2007 Street Bob with out any modifications if I use the 25mm axle, nut, washer and 25mm axle spacres of the 2010? Basically, I want to use all the wheel mounting hardware off a 2010 to mount it to a 2007 without buying new hardware or modifing any parts if possible, the bearings in the wheel are new and all the 25mm parts from the 2010 are on hand.
So in my situation I had to order a Fat Bob front axle, went with Fat Bob trees.
The deluxe wheel I used required 1 ¼" and ¾" spacers. The front 25mm axle I ordered came with two 1" spacers, so I ordered an assortment of 13 25mm spacers on ebay. I've used 3 of them.
The stock size 1" spacers on the '07 street bob appear to be ⅞" and ¾". I'm using a tape not a micrometer. If your sure you need ⅞" and ¾" 25mm spacers-I have them.
I'm not sure the caliper on the newer front ends are the same...the rear is not, thats why I used the third spacer in my situation.
Anyway-I have a bunch of 25mm spacers and can part with 2- double check size and let me know. I send priority 2 day, you send a 10 dollar bill to return address to cover shipping and time, no need for paypal. Or if your not sure you can go to ebay and buy the 13 pack for $47. PM me if you want me to send.
Lu
03-20-2010 09:34 AM
