fabricate windshield?
The best thing for cutting plastic in a home shop is a spiral saw, like this one:
http://www.homedepot.com/p/Rotozip-R...5-10/203408190
Agreed. I've done many myself this way, works perfect every time. Then I take a sanding block and wet-sand with 400 grit wet/dry sand paper to smooth and even up the edge. Then follow that with 900 grit wet/dry and you'll have a smooth factory edge. It really is simple to do.
Plus one on the painters tape and jig saw. I just cut my windshield down last week. (Edge of the shield was right in my line of sight with the new seat) Used a file to clean up the saw marks, 400 grit paper to smooth it out, then steel wool for that factory smooth finish. Looks better than downtown.
I've done 2 with a dremel and a milling bit. It works, it's not easy to control so the line will be jagged, so you also need a table top belt sander to clean it up, then you can wet sand it with fine grit to polish it. I don't know what you'd do with out a flat belt sander. I guess a sanding block or file would work, it just would take a lot longer.
