accessories wire
Old 01-03-2015, 12:01 PM
apetterez's Avatar
apetterez
apetterez is offline
Default accessories wire
I just bought the demon heat grips and it says to tap into an accessory wire I do not know what the color code is or where to find the end of an accessory wire hopefully some of you can give me some assistance
2003 fxdl
Old 01-03-2015, 12:58 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
2003 fxdl
Your Dyna model has a hot wired so called B+ plug under the seat. More info on this subject to be found over here:
Electrical Connection Question
I wouldn't connect the 12v power feed to the B+ though:
1. IT IS HOT ALL THE TIME
2. IT IS NOT FUSED
Edit:
See post # 3
Old 01-03-2015, 01:38 PM
FXD2003Rider
Did some Google searching and I think I found the wiring diagram for your heated grips:
Looking at this diagram, I noticed there's no option to control the power for the grips like H_D heated grips have (see image below).
In order to be able to have the grips circuit controlled by the ignition switch I'd recommend to add a fuse holder in the red wire and follow the instructions at page 7 under ORANGE/WHITE LEAD CONNECTION TO SWITCHED POWER SOURCE for the 2003-Earlier Dyna Models.
Old 01-03-2015, 01:59 PM
monster715's Avatar
monster715
monster715 is offline
Yep I spliced my heat demons red wire to the orange/white wire on the left side control harness
Old 01-14-2015, 10:02 PM
apetterez's Avatar
apetterez
Default switched accessories powet wires
To install the heat demon heated grips i just purchased It says to tap into the orange/white wires to get power for them as they are the accessories wire. Do u know if that color coded wire is switched so that they dont continue to drain. My battery after i turn the bike off?
And where is the best place to cut and make that 2 way splice?
2003 fxdl
Old 01-14-2015, 10:06 PM
Nitro 54's Avatar
Nitro 54
Nitro 54 is offline
Heat demon has a install video that show what to do in steps.
Old 01-14-2015, 10:31 PM
monster715's Avatar
monster715
Yes it's switched. I ran my heat demon wires down the loom with the rest of the wiring harness and spliced them a couple inches from the plug
cosarguy
Milwaukee Eight (M8)
02-10-2024 09:22 PM
cookiemech
20
10-16-2020 06:07 PM
B00001
13
01-15-2017 07:47 PM
klimoman
01-20-2014 03:24 PM
thatguy
11-13-2007 05:26 PM
Quick Reply: accessories wire
