Doing a bar swap on my 2012 WG and need help relocating the front turn signals down near the triple trees. Any of you guys done this, if so how did you go about it?
To the OP. Buy a service manual, two connectors and four pins. Review the wiring diagram for the front lights. The diagram will identify the ground, running light and signal light wires. Hook up the ground and signal wires. you will have to extend the pigtails from the lights that you have. Solder and heat shrink are a must.
OP already bought the turn signals from Joker Machine. Needs help on how to wire them up. The original signals are 3 wire and the new ones are 2 wire.
You canuse the TrueFlex Dual Converter that Cusomdynamics make to take the three wire setup to the two wire on the Joker lights. Also, the Jokers are LED too if I remember correctly, this converter will also send the signal back to the comuter so it doesn't think you have a burnt out light and make the signal flash faster. They are all the way down the page I linked. You'll need one for each light, and its only a $5 investment.
