Joker Machine LED front turn singal install/Questions
Hi guys im doing my handlebars shortly here and was wondering if any one has installed these
http://www.jpcycles.com/product/306-677
i like these alot and had a few install question do i have to either take apart my triple tree or lower forks? is there a way around that also do i need a load equalizer as these are LEDs
if anyone has any comments that would be nice thanks guys
There are cheaper, just as effective load equalizers, if your willing to do a little soldering. For $5 each (light) you can put the TruDual Converters from Custom Dynamics. They are down towards the bottom of the page. There is a video of my ride on this same page showing the are work with the rear lights, same process as the front, dimmer running light, brighter flashing light. I have used thes with many different setups, very reliable and CD's customer support is great.
I had these on my Street Bob and I used the Custom Dynamics Dual Converter. A couple of things to know.
- These rings do not separate entirely, so you need to pull the fork tube out of the top clamp to get these on. (Unless Joker changed them in the last two years.)
- If you want run and turn, you will need the dual converter. If you want turn only, just cap-off the running light wire from teh bike's harness.
- Pay attention. There is a distinct right and left due to the direction the LED is pointing. You don't want to do it twice (like some dummy I know (me!))
- The lighted portion is very small. Even though they are fairly bright, car drivers rarely see them flashing in the daytime.
- The anodized coating will fade within a year. Wipe them regularly with SPF protectant (like 303 Aerospace coating.)
Elvira
02-05-2012 12:19 PM
HWY RIDER
03-21-2011 03:04 AM
