Thunderheader wrap...Can't make up my mind!
Hey guys,
I picked up a black thunderheader exhaust off a buddy for a pretty good price...I think?
The guy doing the exhaust says without the shields I'm going to burn my boots, jeans, leg etc. so I need a wrap. I never LOVED the look of the wrap but I've seen a few really good jobs...just not on 'club style' bikes.
I wasn't a fan of the wrap look either and I was hell bent on a deep black look if I had to do it. I bought some nice Black wrap off eBay and when it arrived, I found that it wasn't very black. More of a deep charcoal color. But I wrapped them anyway and figured I'd spray them later. But once the wrap dried and I seen it in the sun, I really liked the look.
As Deadhead77 wrote, after you wrap the pipes, you spray paint them. You can use either VHT paint or the Silicone paint the DEI (a company that sells the wrap) sells. After time, the paint may fade a bit over the hottest parts of the pipe and then you just spray some more paint on the faded parts. The paint helps keep the heat in, keeps it looking nicer, and keeps moisture from soaking down to the metal. Here's a picture showing my wrapped Thunderheader that has been sprayed...
I talked with a lot of people about this prior to recently wrapping my pipes because I've heard mention of rot as well. The consensus I got was that if the pipes are kept dry, it isn't an issue. One friend that's been a service tech for HD over the past 10 years, and also has his pipes wrapped, said he has seen this in some bikes that he's serviced. But that it's been on bikes that are left outside in the rain or park in the salt-air humid climate of the coast line. He also suggest that if you do get caught riding in the rain, to just run the bike until the wrap is dry and there should be a problem. I guess time will tell.
Just out of curiosity have any of you guys pulled the wrap off a header with around 20-30k miles? I'm not knocking anything so please don't take it that way, I've just always been worried that the wrap will rot a pipe faster.
To the OP, if your worried about burning your pants get a couple heat shields for the pipe, your going to have a hard time keeping that pipe black, BBQ paint isn't goint to hold up, it'll burn up the first time you ride it. If you want to spend the money on high temp powder coat, then with a good tune, it should stay black. But that's expensive... This is one big reason I have a hard time recommending a thunderheader to people, don't get me wrong, I like mine but that thing runs hot
Wrap really destroys the pipe. I've had the same problems on my Buell and the dyna. The wrap does exactly what it's designed to do and holds the heat in the pipe, and with a thinner metal like the th it gets really brittle and comes apart everywhere, the pipe on my Buell actually exploded. Not to mention holding water in and making it rust. You're basically spending more money just to ruin an expensive pipe. I can't understand how anyone could burn themselves on the pipe. Holding my leg or feet against a pipe has never been part of riding anything for me and if your pipe is that hot your bike is begging to be tuned properly!
To answer a couple of questions. On my current set up as shown in the photo, the Thunderheader is wrapped with black DEI wrap and sprayed with black DEI silicone paint. I only have about 1000 miles on this set up so it has not had time to fade at the hot spots. In the past, on another 2-1 pipe, I used black DEI wrap and black VHT or UHT (the one rated for the hottest temps, which ever it is) from Walmart. I probably resprayed the faded hot spots every 4 to 6 months. Very little needed respraying but I thought it looked better with a uniform color. I never bothered to remove the pipes from the bike for resraying, I just stuck a piece of cardboard between the pipe and the bike and sprayed away.
I don't recall the brand off hand. But I'll check when I'm at the shop and post the link. I didn't spray mine at all, that's just the color of the wrap. I thought I'd have to spray it, but once it dried and I seen it in the sunlight, I really liked it. So no need to spray.
Man, I've been looking all over the web to see if I can find anyone who has a vivid black bike with a black or titanium wrap. I know everyone seems to lean towards the denim black but if anyone has or has pics of a vivid black bike with wrapped pipes PPLLEEAASSEE post them.
Didn't think this would be such a hard decision.
Thanks!
Thanks!
Thanks!
Thanks!
