92 FXRS loss of power cutting out. Help?!
Hi everyone I'm new to the forum and am in need of advice.
I have a 92 FXRS. I will be riding along everything will be running/ working as it should then all of a sudden the bike will cut out, lose power and bog down. The headlight and gauges will dim, the gas gauge needle will drop and the bike will want to stall. If I twist the throttle the bike will surge back to life and run for another 30 seconds then repeat its self. It's happend about 3 times in the past 6 months. The last time it happens it left me stranded about an hour from home.
I've replaced the ignition module(happend before and after replacing it) I've replaced the ignition switch. I've replaced the motor to frame ground strap. I've checked almost every wire on the bike for exposed wire. I've checked the battery connections. I feel it's not a fuel issue due to the fact my lights and gauges will drop/dim. Any advice would be greatly appreciated, I'm at the point of pulling my hair out trying to track down this problem...
From what you have described it sounds electrical. Do a full charging system diagnostic check (check at operating temp also). A quick check, open up the primary(bike needs to be level supported off the kick/jiffy stand, if not primary fluid will spill out) and if you smell a strong burnt smell more than likely the stator has gone bad or the clutch is burned(you would know if its the clutch by it slipping), check the primary fluid to make sure its at the correct level.
More info on the bike all stock/any modifications/service history?
If you dont have a service manual get one, worth every penny. You will also need a volt/ohm meter for the charging system check. If you dont feel comfortable working on your bike find someone in your area that is a competent motorcycle mechanic.
Hope this helps, keep us posted.
Tom Pietkiewicz
Electrical/Lighting/Alarm
11-16-2016 03:21 PM
Hawthorne121413
06-29-2013 04:25 AM
The_Cursed_Roadking
06-03-2010 05:58 AM
