help with 07 dyna starter grinding
Just replaced starter, battery and upgraded the compensator to the new screaming eagle high torque comp starter clutch is grinding on the pinion gear of the clutch.!!! Wtf is going on here?? Bike was doing this before I replaced all this hoping it would fix it any ideas??
same problem
Ya kno, i've had the same problem. Rebuilt the starter with the new gear drive and it didn't happen as much in the beginning, and then all of a sudden its doing it again. Im willing to bet its the crank gear thats the problem in both cases..........curious to hear other peoples responses......
Does it do it every time?, this may sound crazy but my 07 FXD has done something similar twice, once the battery cable had work loose and it would not have a good contact and it would make a grinding sound sometimes when I hit the starter, the second time the ground was loose. Mine was weird and I finally figured it out when riding, if I turned right the bike would sputter like it wanted to shut off. Probably not it but worth a look
Had a similar issue on neighbour's 06 Street Glide... starter would grind once in a while, found the back side of the ring gear was ground pretty good. Only thing that comes to mind was PO had hit the starter button while engine was already running, burred up the teeth a bit, which prevented the starter from engaging fully whenever in that 'spot' Situation progressively got worse over several years.
We bought a replacement ring gear kit (aftermarket only) and fixed it.
marine_hm@hotmail.com
12-04-2012 10:46 PM
