Installed 106' Big Bore kit now speedo is off
I just finished installing a S&S 106" big bore in my Dyna Low Rider now my speedo pegs out till I get past 300 rpm then it reads 20mph faster than im going plus the odometer is running very much fast like a 5 mile trip is 50 miles now. Do i need to change the transmission gear to a bigger( more teeth?) Or try a different map in my thundermax?
Sounds like you made some changes you shouldn't have.
A big bore kit should not have any effect on your speedo.
Did you change the gearing?
I have never used a tuner like will change the speedo.
I ,use the baker cabel to correct my speedo's
Perhaps someone with more knowledge about this than I do.
Just hook up a laptop to your bike and link the unit. Then go into Basic Settings and speedo cal section. There it will list the code you should be using for your year bike. Done.
Skullman
02-24-2006 12:01 PM
