Shift Linkage Cover
Shift Linkage Cover
2015 P&A catalog does not show that particular cover made for a Dyna. The one they do show is part # 33878-04 but it's slightly different and only fits 97-05 FXDWG and 93-05 FXDs.
The cover shown in your picture is made for 99 and later Softails and has part # 46304-01
That one MAY fit your Dyna. You'd be wise to measure before you purchase.
Good luck !!
Good luck !!
I replaced the stock setup on my '13 Wide Glide almost immediately after I purchased it with a +3" extended billet shift rod with heim joints, a bit of tweaking and it turned out sweet, I'm too new in these parts to post images I believe or I'd put up a couple so you can see how it turned out... much better than stock!
mrsr71
12-06-2006 10:21 PM
