Wheel bearing question
Old 03-26-2015, 08:47 PM
Vuoso86's Avatar
Vuoso86
Vuoso86 is offline
Default Wheel bearing question
Not sure if this has been answered before I've searched and I'm just getting confused. I'm in the process of putting 13 spokes on a mid glide dyna. I was unaware that my 25mm bearing were actuall thinner than the 3/4 or 1" sealed bearings. Does any body make a 25mm bearing that is the same thickness as the 3/4, and 1" bearing? Or Is there kit that has a spacer and a longer crush sleeve so you can use the 25mm bearing in a hub meant for 3/4 or 1" bearing. Any help or insight would be great. Thanks.
Old 03-26-2015, 09:51 PM
razors edge's Avatar
razors edge
razors edge is offline
try a bearing store in your neck of the woods. around here a motion industry is the name of the store. look in your yellow pages under bearings. good luck
Old 03-27-2015, 01:42 AM
John_K's Avatar
John_K
John_K is offline
You should be able to get the proper spacers from the parts counter at your dealer.
edit: oh and the inner spacer needs to remain the same.
Old 03-27-2015, 05:01 AM
Vuoso86's Avatar
Vuoso86
Vuoso86 is offline
not sure i follow if the bearings get a spacer that would make them further apart meaning the crush sleeve would need to be longer, no?
Old 03-27-2015, 07:30 AM
02fx4dude's Avatar
02fx4dude
02fx4dude is offline
I use SKF 5205-A2RS 25mm ID bearings. They are 20.6mm wide, same as the 1" and 3/4" ID bearings, sealed, and true dual row. Decent bearings.
Old 03-27-2015, 08:21 AM
razors edge
Why do you think the spacing is gonna change? Are you charging the forks? A bearing store is going to be able to sell you domestic bearings cheaper than Harley dealer as a rule of thumb.
Old 03-27-2015, 11:13 AM
John_K's Avatar
John_K
John_K is offline
the bearing outer races should be seated in their pockets... even though they would be 'deeper' since they're narrower. If you use a wider inner spacer then you risk your hub floating from side to side. I don't know about you but I wouldn't be comfortable with that prospect.
If wider, double row bearings are available as mentioned I would go with that option, especially if it saves you from hunting down appropriate spacers.
Old 03-27-2015, 05:20 PM
Vuoso86's Avatar
Vuoso86
Vuoso86 is offline
Thanks for all the help I got in touch with a local bearing distributer that is helping me sort it all out.
oldschoolhd
05-23-2012 10:51 PM
FLTR2008TRIKE
53
02-12-2012 03:03 PM
MNPGRider
11-30-2011 03:46 PM
rider
09-30-2007 05:26 PM
brazos95
03-27-2007 06:23 PM
Quick Reply: Wheel bearing question
