FLD floorboards and Exhausts - Post Pics
Havent decided for sure yet or not if Im going to swap it out. I do like the sound and performance but am looking for a different style exhaust. I still want a 2-1. I like the VH pro pipe but don't want to give up the floorboards or modify a pipe/shields to make it fit.
The floorboards are a nice feature to have especially on the longer trips. I have been considering changing out my exhaust. I wanted to get the VH Pro Pipe but after hearing from their tech support and your posts, looks like I will not be able to get that exhaust and keep the floorboards. Ill have to keep what I have for now and keep searching.
V&H makes a Pro Pipe for the FLD. I have no idea what the differences are as compared to a non-FLD Pro Pipe, but I do know it comes with a spacer that sits between the right floor board and frame. I could be wrong, but I think the spacer is the only difference.
Mine is an older one, 2000.
I am running Python pipes with the Wyatt / V-Twin footboard kit. This is an exact copy of the Dyna Defender kit 50601-01. It included the boards, mounts, brake pedal, heel-toe shifter and all new linkage. I also use the Dyna Defender engine guard 49218-01.
Everything bolted right up.
Copy that.
Im not sure of the differences in the pipes either. This is the response I was given from VH when I asked about whether the pipe would fit with the FLD floorboards: "Thanks for the email and interest in our products. Yes, the HD floor board kit will affect the fit of our systems on a Dyna. Our systems do not take into account a floorboard and are designed to fit without it."
Im pretty sure this one will fit. To my knowledge, the Switchback and the super glide have the same frame. I think the VH tech gave you a generic answer, and has no real hands on experience or knowledge. I would definitely go for it if that's the pipe you want.
Also, if you compare the side view from that one, with the side view from this one: http://products.vanceandhines.com/store/17569/ , it looks like the switchback front cylinder pipe has a different angle to clear the board mount.
