Acorn Nuts on Exhaust Headers?
I used chrome plated Acorn Nuts & anti-seize on my Exhaust Headers to attempt to prevent corrosion and problems with broken studs in the future.... thinking the nuts would keep the threads clean & dry.
do you folks think this is a good idea?
I think acorn nuts are overkill but since you have already installed them..ok acorn nuts. You don't really need to protect those flange nuts against water, the headers are so hot that evaporation is pretty much instantaneous, and they don't get wet when she's parked. I imagine since you want to put anti seize on there your not having a problem with them coming loose, so my recommendation is some high quality penetrating oil about ten minutes prior to removing them. having rust on the studs is normal IMO.
I don't know if I'd trust just an acorn nut, I always use the exhaust flange nuts. Once I've got the exhaust properly mounted and the flange nuts to spec there's always threading left on the exhaust stud, I then use the acorn nuts as a double nut, I tighten the acorn up against the flange nut. It protects the exposed threading, using them as a double nut keeps the flange nut from coming loose and it gives a nicely finished look.
NO, the pipes are not that blue, it's just the flash in the garage giving that look but man, she's dirtier than I thought
