What to do with my gas tank gauge holes (besides using as beer holders)
I've had my new Low Rider less then 24 hours, and am already thinking about reconstructive surgery.
I'm not happy with tank mounted gauges, as I don't want to be taking my eyes off the road every time I look down at the speedo. I really want to move a single HD tach/digital speedo up to my soon to be installed T bar's. I have a good mount solution in mind which I used on my old FXD. However I will need to do something with the two holes left in the tank console.
I'm playing with the idea of ordering a new console, and having a shop weld in some blanks to cover the holes and powder coat it. But that's probably going to be expensive.
I saw some blanks someone here used, which look ok on a single console, but I think two won't look so good.
Alternately, I could leave both gauges where they are and just mount the single combo gauge on the bars, but I'm not sure if the harness will play well with the combination tach/dig speedo, in place of the two actual gauges. Plus it will probably look stupid with three gauges on the damn bike.
I don't want to go down the road of sourcing a FXD tank, just too costly.
It would make life easier if the 2015 parts fich's were out too.
Any suggestions?
Any suggestions?
I cut the peice out that had the holes in it... (the speedo hole and the ignition switch hole)...
this gave me one big hole... I then made a template out of sheetmetal to fit around the one big hole.
I cant weld and didnt want to spend money I didnt have so I fiberglassed it with one of my layers being the metal template to add strength. only once the fiber was attatched to the dash I trimmed the edges and painted. pretty easy but a little time consuming.
Wish I had taken pictures of the whole process.
here are some before and after pics. hope this helps with some ideas.
Yea I was thinking that route after I did all the work... really dont wanna put the bike down right now weather has been way to nice. maybe in the future. keep posted want to see how yours turns out.
