Soldering turn sig wires tips or Tricks?
#31
#32
#33
All my rear end and handlebar wiring has been stranded. I think it's because of the AMP connectors can't see using solid wire with those.
#35
In four pages, nobody has told you that you bought the wrong (silver) solder (much higher melting point making regular splice joints way more difficult).... Get some 60/40 rosin core radio solder, you don't need external flux, practice getting the wire hot before you apply the solder, and melt the solder on the WIRE, not the soldering iron tip. I hope you got a 25 watt or higher iron, a Weller 100/150 watt gun would have been preferable, i've bought several at yard sales for next to nothing. A proper solder joint is always preferable to a crimp, when you can use it, unfortunately too many people produce cold solder joints, ignore them and then blame that for failure of a splice. BTW - learn to solder and it's one of those skills they'll never take away from you.... and a lot of people are afraid to try.
#36
#37
Well actually someone did mention it getting the wires from a wide glide which are longer, I imagine I could do that as well but Frankly at this point for the $9 in wire I'm kind of looking forward to trying learning something new!
#38
Rosin core solder is better than silver I agree, and that's what we use at work WITH the help of external no clean flux. I don't agree with just heating the wire though I was never taught that way you always tin the solder tip first. To each his own.
Robby, as far as I can tell the sig wires are 18awg stranded.
Good luck brother!
Good luck brother!
#39
Good luck brother!
Good luck brother!
#40
Those joints are pretty nice:
Solder Heat Shrink Terminal Installation - YouTube
Never knew about them. I think I'd be comfortable using those but as STRES said you can't be 100% sure if you can't see. For me I have all the nice wiring tools and lots of practice so I'm fine doing it the old fashioned way.
