Chain conversion first 400 mile review
I was looking at swapping pulleys but keeping a belt drive until I found out about Zipper's chain conversion kits. I was really worried about losing the ability to do longer rides without having gas mileage make me stop every 100 miles. Between the pain that it is to swap the transmission pulley or sprocket and belt while wanting to easily change ratios I went with the chain.
I have been incredibly happy with it so far. The increased power is awesome. I went from the stock 2.06 ratio to a 25 tooth trans and 57 rear sprocket giving me a 2.28 ratio. And now I can do wheelies. The maintenance isn't fun but it also isn't hard. The factory grease or belray haven't left much in the way of residue anywhere except for a bit on the frame I've noticed, but it isn't so much I mind at all. The noise is hardly noticeable above wind and exhaust and only because I'm intentionally listening for it.
My only question for anyone with more experience dealing with chains is if I go for a 3000 mile tour to see family in Oregon, do I need to stop every 400 for the recommended cleaning and lube or can that be stretched to just before and immediately after the trip?
RK Chain's are very good. Any modern Japanese made chain is gonna be solid and last many miles with just general care. Any idea on size? My guess is a 530, which is the beefiest street chain.
I've gone on many long-distance trips using chain driven bikes. For a 3K trip, I would set tension and lube it right before I leave, lube it some where half way through, and that's it. If your running through some really dusty conditions, may have to clean it and lube it a little sooner, but for general riding in decent conditions (even a little rain), my guess it would be safe to lube 1 or 2 during the entire trip. Should not have to adjust for tension unless your riding it extremely hard with alot of weight.
I didn't like Motul stuff cause it tends to fling off. I like the Dupont Chainsaver Wax cause fling factor was minimal and easy to get. Another great one is Original Bike Spirits Chain Lube, but had to buy it online. Another great low-fling chain lube.
I went with the 530 chain, they have the option for drag race chain but my 103" doesn't need that big and it's non 0-ring. I'd rather limit the extra wear and lube needs when the 530 can handle way more than I need. I figured and hoped I could get away with carrying lube but didn't want to be trying to use cleaner and be scrubbing the chain in a parking lot a couple times a day. So far in pretty clean conditions I haven't noticed really any build up of dirt or grime. It's obvious there is some discoloration etc but the cleaning didn't seem necessary after 400 miles.
Been running a chain for years on the street and maintenance is no big deal.
Lube it before your long trip, then as said, maybe a quick lube during the journey, then when you get there. Don't worry about it.
Modern chains last a long, long time and RK makes a great chain.
BTW, what's your final drive ratio now?
Enjoy the trip!
Enjoy the trip!
Enjoy the trip!
Enjoy the trip!
Thanks for the advice. Talking with more of the sport bike guys I know it sounds like the manufacturer recommended 400 mile service is kind of overkill. But when do manufacturers not overdo service recommendations.
From what I've heard the primary drive ratio is 1.35, the new final drive ratio is 2.28 (25 trans, 57 rear wheel), so the over all is 3.08. With my engine output it's pretty perfect I can get the wheel up if I work for it, but it doesn't come up every time I goose it.
