Forward to Mid question.
With fwds, I would expect the longer shift rod. I was very surprised to hear that the shifter lever that runs through the primary was left in - makes me wonder which transmission shifter is installed...
Mine still has the original shifter lever in the primary too even though i have forwards...was like that when i bought it.
I'm going to need to take a closer look when I get home, (AM). I don't recall seeing the other shift lever coming out of the primary, this being my first bike(HD) in a very long time I'm not up on all the parts. I wasn't sure, I thought maybe I could just move the shift lever back. I really didn't/don't want to remove the primary.
The reason it seems a bit odd is because the transmission shifter is different for mids or fwds, I guess you might be able to use one for the other but I would think if the correct transmission shifter was installed for fwds then you might as well pull out the shifter lever that goes through the primary... just wondering.
I went out and took a look at the shifter side, the lever for the mid controls is still intact and I have the original shift linkage for the mids. I believe this is going to be a cake walk, my only concern is the brake side now, I do have all those parts as well, but curious if theres anything I need to be aware of. Thanks guys.
BYW, Thanks for this HDPilot, this helped a great deal, this is going to be easy.
I just did this mod a few weeks ago. Here is my thread, may help some:
https://www.hdforums.com/forum/dyna-...-mids-mod.html
