Superglide custom project overview-Susie
[hr]
[hr]
Hi,
Some of you already know of the transformation that is taking place with my 2005 Superglide FXDI. Since it has been awhile, I thought I would list the items awaiting installation and the 2-3 items left to get to finish the project. I call this "Susie's" EXTREME MAKEOVER!!!![&:]
Items awaiting installation:
-Rick Doss 41mm forks, waterfall design, 3 degree rake, all chrome
-3 degree bearing cups, custom milled by "R Racing" to work with the Doss forks
-13" Mini-Ape Hangers with chrome levers and switching, black buttons
-All cables braided steel with clear plastic coating
-21" Narrow hub front wheel, hub, spokes, nipples, rim~everything chromed
-Hawg Halters narrow hub to 41mm Fork Adapter kit, polished billet aluminum
-front and rear Harley replacement brake calipers, all chromed
-Harley-Davidson Sportster 1200 Custom chrome disc rear wheel (500-800 miles on rim)
-complete rear wheel bearing rebuild kit so it is brand new/fresh when installed
-2nd set of 2005 FXDI sheetmetal for custom paintjob, with CCI "FXR" front fender
-Custom milled fork stop by Reichard Racing to allow Softtail forks to work on a DYNA frame
-chromed button head screws to fill in holes on right side of front hub
-front turn signal relocation brackets to fork tubes, chromed
-Dream Weavers Pro Street license plate bracket, Horizontal mount, Model A tailight,vintage lense
-Billet aluminum 5 3/4" diameter headlight, 7 inches long, Tri-Bar with clear lense
Still to purchase:
-Roland Sands Valve covers??
-Kuryakyn 1" dia. turn signals front and rear??
Note:
The custom paintjob will be one of about 3 different themes I'm still kicking around in my head.....black base with old skool yellow faded to orange flames, satin powdercoat gold or silver, or a dark green candy over black base marbelized finish. The rear fender tailight hole and other holes will be filled and shaved, as I have a Dream Weaver Pro Street horizontal flat license plate setup with Model A tailight with the vitnage red lense......
Other than that, my Superglide will be finished! This is how you waste alot of $$$ on a Superglide that is worth next to nothing if you ever sell....since I decided to keep her, and forgo getting a 2nd bike, I decided to build this one up!
Joe
RE: Superglide custom project overview-Susie
Installed to date-not mentioned above....see the picture here. It has currently installed:
- Progressive 412 Heavy Duty rear shocks
- S&S 510G gear driven cams
- Screamin Eagle Chromoly adjustable pushrod kit
- Screamin Eagle Primary "Gear Down Kit"
- Screamin Eagle pressure plate for clutch
- Harley-Davidson Factory Stage I download, for higher RPM redline and timing bump
- DynoTech Power Commander III USB
- DYNO tuned
- S&S Mufflers
- Billet pegs and grips
- Memphis Shades 21" tall windscreen
- Kuryakyn LED super low profile tailight
- Laydown license plate frame
- Turn signal rings from the MOCO accessory book
- Harley-Davidson Forward Controls
- 1958 Harley-Davidson emblems on derby cover and on FXDX black krinkle battery box cover
- Arlen Ness Cafe Front fender (made from ABS), painted factory Chopper Blue
- High end solo seat, real leather, with Harley-Davidson logo sewn in on the back of seat
- small oval bar and shield air cleaner cover
- Arlen Ness Big Sucka intake system
That is what is installed....all the parts I mentioned in the first post I already own...just have to install when I return to the USin 4.5 months.
Joe
- DYNO tuned
- S&S Mufflers
Joe
S&S 510G is a real strong cam in a stock 88
510G's require NO cam chest clearancing, if you cut the old pushrods out with bolt cutters and use adjsutable pushrods, the top end doesn't even have to be touched, saving a ton in labor costs and down time! (I used the Screamin Eagle adjsutables....VERY nice!)
510G's work with stock valvesprings
Keep in mind....this is a 3,000+ RPM range cam. Has a real lopey idle, and gear driven cmas have a little whine to them!
The bike WILL have to be-retuned after isntallation of this cam.
IMHO...don't even think of using this cam if you want the stock mufflers and intake....waste of $$$$
If you want a stock type gear drive cam, go with an Andrews T-26 of something like that....this is a Hot-Rod cam that works with stock compression, and you lose no reliability.
Lastly...it's made by S&S....Nothing more needs to be said.
Joe
Joe
