Unused electrical connection
That accessory plug is under my 2008 Dyna Super Glide Custom also. Like was posted before aux. lights, example: I have fog lamps ready to be installed on my engine guard. They will plug right into that accessory plug! That accessory plug also can be used for aftermarket sound system, led lights, etc.
Should be HD part numbers:
Socket Housing - 72116-94BK (housing is black in color) or 72136-94GY (housing is gray in color)
Terminals - 72191-94
Seal pin - 72195-94 (used to seal unused ports in the connector to keep it weatherproof).
Learned this from a fellow Dyna Rider poster. Had to go look for this in my garage! H.D. p.n. 70264-94A Harness, Dual Accessory can be used to plug into this female harness line. If you use this two-into-one harness adapter per "INSTRUCTIONS" sheet "cavity (terminal)". Looking at male connector (locking piece) top left wire hot (positive)-top right wire cold (negative). Bottom left wire cold (negative)-bottom right wire hot (positive). This fellow Dyna Rider used this two-into-one harness to add additional accessories! He just cut the female connects off to hard wire into this harness.
Heated clothing, gloves, etc. is through the connector plug that you use for battery tender. And yes this electrical connection can be used for heated grips.
