Installing SE Custom T Bars
LMAO!! That is exactly where they are! I found them before checking back in, but thanks Robbyville, you have been doing me a solid the last 24 hrs. I appreciate the help.
Just to throw it out there, when I did my bars on my 08 FXD (and soon to again on my new low rider - as soon as my bars arrive!) I took some paracord and usimg blue painters tape, taped off all the holes in the bars except for the entrance and exit holes. Put a shop vac up to one and used it to pull the para cord through. Took about 3 seconds, once the taping was done. Tied a loop, put the cable bundle through the loop and taped the hell out of it with electrical tape. I also sprayed the cable bundle with silicon to lube the pull. Having someone push the cables through, while you pull the cord helps too.
