1000 miles oil change diy problem!!
Hi, first i'm new to this site and french speaking so sorry for my english writing. I've just made my first 1000 miles service myself, primary case, transmission and engine oil change. I have a 2015 Fxdb with v&n straight shots slip on, s&s high flow air cleaner and v&h fp3 autotune map. The problem is that yesterday i've change all my fluid, and today i went for a ride and it was smelling burned oil, so i've check the engine temp with the fp3 app and i've saw 300 F degree. When i've get back home 10 km later i've check the oil dipstick and was half an inch over the hot line. So i've remove the excess oil with a turkey juicer and put it on the hot line, then i check the oil color in a water bottle and it is already black 70 km later after the new oil change. So is 300 F degree is normal ? and is the black color oil normal too? Thanks lot guys!
I'm unsure of what temp the oil runs. But you'll never get all the oil out of the engine doing a standard drain and I'm sure that's what most of us do. So your oil will turn black quicker than you think. As for the smell-any leaks or drips anywhere? Could have spilled some and then the engine got hot?? Just my opinions. I'm no expert. I should also add that I'm not exactly sure how far 70km is but doesn't seem very far.
no that's not normal at all, something is wrong, were you riding it hard? did you replace the filter using a new Harley filter? I only use Harley filters just to eliminate the chance of getting an inappropriate filter that may not work correctly on a vtwin.
the oil should stay around 260... 300 is too hot, of course I don't know how that app works, is that the oil tank temperature?
the oil is black because you've fried the oil and it was burning.. that oil should be changed again.
honestly, you might want to take it to a dealer just incase there is a problem that your warranty would cover.
as dud said it is common to spill oil on the motor which can cause a buring il smell but I'm afraid you might have a bigger problem.
Yess, i have change the oil filter with a premium harley one and put 360 20w50 mineral oil in the engine. No drop at all on the floor or wherever, And i was smooth on my 70km ride.The fp3 app said engine temperature So i guess is the oil temp. I will call the dealer tomorrow.
Do you think i need to replace the new filter too?
The measured temp is the head temp. Depending on speed, temp outside, idle time, stop and go etc can vary to that temp. The extra qt of oil that doesn't drain will make the new oil when a few miles are added a tad discolored. All normal. International bikes have some added emission features that may bump the temp up as well. Also depending on what cal the fp is running may not be correct for the bike.
on second thought you might be okay, it 300 is your engine temp them that might be the cylinder head temperature & not the oil tank.. 300 engine temp would be normal.
I think you are alright..
the burnt oil smell might be just from over filling and the engine venting the excess oil back into your intake.
Harleys are funny, it's better to fill the oil a little low so it doesn't;t spit out...
